A reliable cable labeling system is essential when planning and
installing a network.
Keeping accurate records helps you to:
- Relocate devices easily.
- Make changes quickly.
- Isolate faults in the distribution system.
- Locate the opposite end of any cable.
- Know the types of network devices that your cabling
infrastructure can support.
Follow these guidelines when setting up a cable labeling system
suitable for your installation:
- Identify cables by securely attaching labels to all cable ends.
- Assign a unique block of sequential numbers to the group of cables that run
between each pair of wiring closets.
- Assign a unique identification number to each equipment rack.
- Identify all wiring closets by labeling the front panel of your Extreme Networks
equipment and other hardware.
- Keep accurate and current cable identification records.
- Post records near each equipment rack. For each cable drop, include information
about the cable source, destination, and jumper location.
