Log In for the First Time on Fabric Engine
Onboard your switch with ExtremeCloudTM. Log in or create your XIQ administrator account in order to select your switch operating system with XIQ at https://extremecloudiq.com
Before logging in, verify that the switch LEDs are on (solid green or blinking green) and that it is connected to a management console as described in Connect to a Management Console.
To perform the initial login and complete initial configuration tasks, follow these steps.
  1. Using a terminal emulator such as PuTTY or TeraTerm, connect to the switch using the serial port connection.
    Be sure that your serial connection is set properly:
    • Baud rate: 115200
    • Data bits: 8
    • Stop bit: 1
  2. Press [Enter] one or more times until you see the login prompt.
  3. At the login prompt, log in using the default user name rwa.
    For example:
    login: rwa
    When prompted for the password, enter rwa.
    When you are logged in with the role-based authentical level of rwa, you can configure the login and password values for the other role-based authentication levels.
