Whether you are running in LRM mode only, or in LRM plus MACsec mode.
Whether you are using an auxiliary power (USB) cable to draw additional power beyond what is provided by the host switch.
The figures listed assume that, in every case, both adapter ports are connected to the host switch. The adapter will not operate properly if only one port is connected to the host switch.
| Switch Model | Mode: LRM Only | Mode: LRM and MACsec | ||
| Two ports no aux. power | Two ports 0.5A aux. power | Two ports aux. power1 | One port One bypass aux. power1 | |
| 5320-16P-4XE 5320-16P-4XE-DC 5320-16P-2MXT-2X | 2 | 2 | N/A | N/A |
| 5320-24T-8XE 5320-24P-8XE | 2 | 4 | N/A | N/A |
| 5320-48T-8XE 5320-48P-8XE | 22 | 4 | N/A | N/A |
1With 1W optics modules (SR, LR, LRM, 10 km bidirectional, AOC, DAC, and most 1 Gb optics), use 0.5A auxiliary power sources.
5320 Series
48-port systems can support one LRM/MACsec Adapter without auxiliary power if two additional SFP+ ports are unused.5320 Series
48-port systems can support two LRM/MACsec Adapters without auxiliary power if four additional SFP+ ports are unused.
