Adding a member port to a port channel Follow this procedure to add a port to a specific port channel interface at the interface configuration level. If the port channel is not created, this task creates the port channel and also adds a port to the port channel.
Configuring the minimum number of LAG member links Follow this procedure to configure the minimum number of LAG member links that should be functional so that the port-channel interface is operationally up.
