Configuring a new port channel interface
Follow this procedure to create a new port channel interface at the global configuration mode.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the interface port-channel command to create a new port channel interface.
    device(config)# interface port-channel 30
The following example creates a new port channel interface of 30.
After creating a new port channel, you can enter no shutdown or shutdown to bring up or down the port-channel, as follows:
device# configuration terminal
device(config)# interface Port-channel 30
2016/10/17-20:31:21, [NSM-1004], 302, M2 | Active | DCE, INFO, SLX,  Port-channel 30 is created.
device(config-Port-channel-30)#
device(config-Port-channel-30)# no shutdown
2016/10/17-20:31:26, [NSM-1019], 303, M2 | Active | DCE, INFO, SLX,  Interface Port-channel 30 is administratively up.
