Configuring an edge port
To ensure that the MVRPDU is not exchanged on the edge port, set the applicant state as non-participant on the port.
This procedure assumes that MVRP is enabled on the device.
Perform the following steps.
  1. From privileged EXEC mode, enter global configuration mode.
    device# configure terminal
  2. Configure an Ethernet interface and access interface configuration mode.
    device(config)# interface ethernet 0/1
  3. Enable MVRP on the interface.
    device(conf-if-eth-0/1)# mvrp enable
  4. Configure the applicant mode of the interface to non-participant.
    device(conf-if-eth-0/1)# mvrp applicant-mode non-participant
    The default applicant mode setting for this command is normal-participant.
The following example are the steps in the previous configuration.
