The following sections discuss working with VLANs on Extreme devices.
Section contents:
Configuring a VLAN Follow this procedure to configure a VLAN in the Extreme device at the global configuration level.
Configuring a switchport interface Follow this procedure to configure a switchport interface in the device to send and receive data packets.
Configuring the switchport interface mode Do the following to set the switchport interface as access or trunk. This configuration works only when the interface is set as switchport.
Configuring the switchport access VLAN type Do the following to change the switchport access VLAN type. This configuration works only when the interface is set as switchport.
Configuring a VLAN in trunk mode Do the following to add or remove VLANs on a Layer 2 interface in trunk mode. The configuration is also used to configure the VLANs to send and receive data packets.
