This task configures VxLAN LVTEP
support, which includes loopback, VLAN, Ethernet, and bridge domain (BD), overlay gateway,
and MCT cluster configurations.
Configure multiple loopback interfaces to support BGP neighbor address-family and the LVTEP IP address.
Enter global configuration mode.
device# configure terminal
In global configuration mode, specify a loopback port number.
device(config)# interface loopback 1
Configure a loopback interface with OSPF area 0 and an IP address, and enable the interface to support BGP neighbor address-family.
device(config-Loopback-1)# ip ospf area 0
device(config-Loopback-1)# ip address 6.6.100.6/32
device(config-Loopback-1)# no shutdown
Configure a second loopback interface to support the LVTEP IP address.
interface Loopback 2
ip ospf area 0
ip address 6.7.100.67/32
no shutdown
The same address is used for both nodes in the cluster.
In global configuration mode, create two VLANs to support a pair of logical interfaces (LIFs) and BDs.
device(config)# vlan 11-12
Configure the LIFs and BDs.
Specify an Ethernet interface.
device(config)# interface ethernet 0/5
Configure the parent interface as switchport.
device(conf-if-eth-0/5)# switchport
Specify trunk mode.
device(conf-if-eth-0/5)# switchport mode trunk
Enable the interface.
device(conf-if-eth-0/5)# no shutdown
Specify a service instance and enter LIF configuration mode.
device(conf-if-eth-0/5)# logical-interface ethernet 0/5.1
Specify an interface and create a dual-tagged (inner VLAN) VLAN.
device(conf-if-eth-lif-0/5.1)# vlan 10 inner-vlan 1
The VLAN in the LIF configuration is for VLAN tag classification. This example shows a dual-tagged LIF being configured. The expected packet that enters through this port must be dual-tagged, without VLAN 10 and the inner VLAN 1, in order to be classified as a packet received for this LIF.
(Optional) By default, the administrative state of the LIF is "no shutdown." To remove the port from participating in any data traffic without having to shut down the physical interface, enter the
no form of the
shutdown (LIF)
command.
device(conf-if-eth-lif-0/5.1)# no shutdown
Repeat Step 3e through Step 3g for the second logical interface, and specify a second inner VLAN.
logical-interface ethernet 0/5.2
vlan 10 inner-vlan 2
Create and configure a BD.
Create BD 1.
device(config)# bridge-domain 1 p2mp
By default, the bridge-domain service type is point-to-multipoint (p2mp).
Bind the logical interfaces for attachment circuit (AC) endpoints to the BD.
device(config-bridge-domain-1)# logical-interface ethernet 0/5.1
Logical interfaces representing BD endpoints must be created before they can be bound to a BD. For further information, refer to
Logical Interfaces.
Ensure that local switching is enabled for BD 1.
device(config-bridge-domain-1)# local-switching
Local switching is enabled by default.
Enable the dropping of Layer 2 bridge protocol data units (BPDUs) for BD 1.
device(config-bridge-domain-1)# bpdu-drop-enable
A default pseudowire (PW) profile is automatically configured, with the following defaults:
Vc_mode = RAW Mode
mtu = 1500
mtu_enforce = NO
pw_profile_control_word = 0
pw_profile_flow_label = 0
Repeat the above BD configuration for the second BD, as in the following example.
bridge-domain 2 p2mp
pw-profile default
bpdu-drop-enable
local-switching
Configure an overlay gateway.
In global configuration mode, specify a gateway.
device(config)# overlay-gateway gw1
Specify the type as Layer 2 extension.
device(config-overlay-gw-gw1)# type layer-2-extension
Specify the LVTEP loopback interface.
device(config-overlay-gw-gw1)# ip interface loopback 2
Configure the automatic mapping of VLANs/BDs to Virtual Network Identifiers (VNIs).
device(config-overlay-gw-gw1)# map vni auto
Activate the gateway.
device(config-overlay-gw-gw1)# activate
In global configuration mode, enable EVPN configuration mode and configure the EVPN instance.
Enter default EVPN configuration mode.
Default mode is the only available mode.
Enable the auto-generation of the import and export route-target community attributes for the default EVPN instance.
device(config-evpn-default)# route-target both auto
Enable the auto-generation of a route distinguisher (RD) for the default EVPN instance.
device(config-evpn-default)# rd auto
Add the BDs to the default EVPN instance.
device(config-evpn-default)# bridge-domain add 1-2
Add the VLANs to the default EVPN instance.
device(config-evpn-default)# vlan add 11-12
Configure the cluster.
mode, specify an MCT cluster name (in this example, "c1") to enable
cluster configuration mode.
device(config)# cluster c1
Specify a port channel
interface through which to reach the MCT cluster peer.
device(config-cluster-c1)# peer-interface port-channel 1
Specify the IP address of the MCT cluster peer.
device(config-cluster-c1)# peer 7.7.100.7
Exit to Privileged EXEC mode.
Configure BGP routing with neighbor and address-family attributes.
In global configuration mode, enable BGP routing and enter BGP router configuration mode.
device(config)# router bgp
Specify the autonomous system number (ASN) for the AS in which the remote neighbor resides.
device(config-bgp-router)# neighbor 7.7.100.7 remote-as 100
Configure the BGP device to communicate with a neighbor through a specified interface, in this case loopback 1.
device(config-bgp-router)# neighbor 7.7.100.7 update-source loopback 1
Repeat the above two substeps for the other peer address, as in the following example.
neighbor 8.8.100.8 remote-as 100
neighbor 8.8.100.8 update-source loopback 1
Enable IPv4 and IPv6 unicast address-family.
device(config-bgp-router)# address-family ipv4 unicast
device(config-bgp-router)# address-family ipv6 unicast
Enable the L2VPN address-family configuration mode to configure a variety of BGP EVPN options.
Enable L2VPN address-family configuration mode and enter BGP EVPN configuration mode.
device(config-bgp-router)# address-family l2vpn evpn
Specify VxLAN
encapsulation for the first peer.
device(config-bgp-evpn)# neighbor 8.8.100.8 encapsulation vxlan
Enable the exchange of information with BGP neighbors and peer groups.
device(config-bgp-evpn)# neighbor 8.8.100.8 activate
Repeat the above steps for the other node in the cluster, with modifications as appropriate.
