Enabling statistics on a bridge domain
Statistics may be enabled for a specific bridge domain.
By default statistics are disabled on bridge domains. After enablement, statistics should be disabled when no longer needed because the collection of statistical information has a heavy impact on data traffic.
  1. Enter the global configuration mode.
    device# configure terminal
  2. Enter the bridge-domain command to create a bridge domain at the global configuration level.
    device(config)# bridge-domain 3
  3. Enter the statistics command to enable statistics for all the logical interfaces and peers in the bridge domain.
    device(config-bridge-domain-3)# statistics
    When statistics are no longer needed, use the no statistics command to disable statistics on the bridge domain.
The following example shows how to enable statistics on bridge domain 3.
The following example shows how to disable statistics on bridge domain 3.
device(config-bridge-domain-3)# no statistics
