In an MCT configuration, LD runs independently on both nodes. With loose mode the user must enable loop detection for the same VLANs on both nodes in the MCT cluster. MCT strict mode and loose mode use cases are detailed below.
Section contents:
MCT strict mode The following figure illustrates a use case for MCT strict mode, followed by a sequence of events.
MCT loose mode The following figures illustrates two use cases for MCT loose mode, followed by a sequence of events.
