Link aggregation enables you to bundle
multiple physical Ethernet links into a single port-channel, providing enhanced
performance, redundancy, and availability.
We also refer to port-channels as
link-aggregation groups (LAGs). A LAG is considered a single link by connected devices,
the Spanning Tree Protocol, IEEE 802.1Q VLANs, and so on. When one physical link in the
LAG fails, the other links stay up. A small drop in traffic is experienced when one link
fails.
When queuing traffic from multiple input
sources to the same output port, all input sources are given the same weight, regardless
of whether the input source is a single physical link or a port-channel.
The benefits of link aggregation are as
follows:
Increased bandwidth (The logical bandwidth can be dynamically changed as the demand changes.)
Increased availability
Load sharing
Rapid configuration and reconfiguration
Each LAG consists of the following components:
Links of the same speed.
A MAC address that is different from the MAC addresses of the LAG's individual member links.
An interface index for each link to identify the link to the neighboring devices.
An administrative key for each link. Only the links with the same administrative key value can be aggregated into a LAG. On each link configured to use LACP, LACP automatically configures an administrative key value equal to the port-channel identification number.
Two LAG types are supported:
Static LAGs—In static link aggregation, links are
added into a LAG without exchanging control packets between the partner systems.
The distribution and collection of frames on static links is determined by the
operational status and administrative state of the link.
Dynamic LAGs—Dynamic link aggregation uses Link
Aggregation Control Protocol (LACP) to negotiate the links included in a LAG.
Typically, two partner systems sharing multiple physical Ethernet links can
aggregate a number of those physical links using LACP. LACP creates a LAG on
both partner systems and identifies the LAG by the LAG ID. All links with the
same administrative key, and all links that are connected to the same partner
switch become members of the LAG. LACP continuously exchanges LACP protocol data
units (PDUs) to monitor the health of each member link.
