LD protocol overview The loop detection (LD) protocol is an Extreme Networksproprietary protocol used to detect and break Layer 2 loops caused by misconfigurations, thereby preventing packet storms.
LD use cases In an MCT configuration, LD runs independently on both nodes. With loose mode the user must enable loop detection for the same VLANs on both nodes in the MCT cluster. MCT strict mode and loose mode use cases are detailed below.
Configuring LD protocol Follow these steps to configure loop detection (LD) protocol globally and at the interface and VLAN level.
Loop detection for VLAN LD loose mode is used to support a shutdown at the attachment circuit (AC) logical interface (LIF) level instead of at the physical port level.
