Edge port and automatic edge detection Configuring the edge port feature makes a port transition directly from initialization to the forwarding state, skipping the listening and learning states.
BPDU guard In an STP environment, switches, end stations, and other Layer 2 devices use BPDUs to exchange information that STP will use to determine the best path for data flow.
Restricted role Configuring restricted role on a port causes the port not to be selected as root port for the CIST or any MSTI, even if it has the best spanning tree priority vector.
Restricted TCN TCN BPDUs are used to inform other switches of port changes.
