MCT Overview Multi-Chassis Trunking (MCT) is trunking that initiates at a single MCT-unaware server or switch and terminates at two MCT-aware switches. MCT allows the links to the two MCT-aware switches to appear to a downstream device as if they are coming from a single device on a single Link Aggregation (LAG) trunk interface or physical port.
Configuring MCT Configure the local and remote MCT cluster and cluster clients.
Configuring additional MCT cluster parameters The SLX-OS device has additional cluster commands with default values. You can change the parameters for these commands in cluster configuration mode.
VPLS and VLL MCT on the SLX 9640 and 9540 devices On the SLX 9640 and SLX 9540 devices, VPLS and VLL MCT are used for data center interconnection in which SLX-OS MCT acts as a data center gateway to connect to another data center through either the VPLS or VLL WAN connection.
Using MCT with VRRP and VRRP-E Standard VRRP and VRRP-E configuration commands, VMAC generation login, and scaling numbers apply when used with MCT. VRRP advertisement packets are exchanged through the MCT ICL.
