To troubleshoot problems with static and dynamic LAG configuration, use the following
troubleshooting tips.
When a link has problem, the show port-channel command
displays the following message:
Mux machine state: Deskew not OK.
Troubleshooting static LAGs
If a link is not able to join a static
LAG:
Make sure that the mode is "on."
Make sure that the port-channel
interface is in the administrative "up" state by ensuring that the no shutdown command
was entered on the interface on both ends of the link.
Troubleshooting dynamic (LACP) LAGs
If a link is not able to join dynamic
(LACP) LAG:
Make sure that both ends of the
link are not configured
for passive mode. They must be configured as active /active, active /passive, or passive /active.
Make sure that the links that are
part of the LAG are connected to the same neighboring switch.
Make sure that the system ID of
the switches connected by the link is unique. You can verify this by entering
the show lacp
sys-id command on both switches.
Make sure that LACP PDUs are
being received and transmitted on both ends of the link and that there are no
error PDUs. You can verify this by entering the show lacp countersnumber command and looking at the receive mode (rx) and transmit
mode (tx) statistics. The statistics should be incrementing and should not be at
zero or a fixed value. If the PDU rx count is not incrementing, check the
interface for possible CRC errors by entering the show interfacelink-name command on the neighboring switch. If the PDU tx count
is not incrementing, check the operational status of the link by entering the
show
interfacelink-name command and verifying that the interface status is
"up."
