To ensure that the replacement node successfully joins the cluster, set the VRRP node priority of the replacement node to a value that is lower than the value of the existing nodes. This ensures that the VRRP address is pointing at a working node in the cluster during the joining process. After the replacement node has joined the cluster, you can set the VRRP node priority to first priority if desired, but this is not required.For information about the Basic Configuration Wizard, see the appropriate Deployment Guide.
What to do Next
After you have gathered the necessary information and verified the software version of all nodes in the cluster, go to the Replace a Node procedure.
