Firewall Requirements
The following connections are required during installation and upgrades so that Universal Compute Platform can download the appropriate packages.
Table 1. Required Connections for Installs and Upgrades
Domain Name IP Adresses Protocol Port
docker.io Dynamic IP range HTTPS 443
gcr.io Dynamic IP range HTTPS 443
Internet connectivity is required in these situations:
Once the stand-alone cluster is created, internet connectivity is not required while installing, upgrading, or running application engines that run on the appliance (unless the specific application engine requires it, or unless you onboarded to the cloud).
If the appliance is to be deployed as an air gap use case, the initial configuration of the host needs to take place in a staging location where internet services are available (for example, DNS, NTP and Docker access). Once the node is initialized to support the target application, the appliance can be moved to its target location.
The following connections are required if you connect to ExtremeCloud IQ.
Table 2. Required Connections for Cloud Deployments
Domain Name IP Addresses Protocol Port Description
hac.extremecloudiq.com 34.253.190.192 ~ 34.253.190.255 HTTPS 443 Onboarding to ExtremeCloud IQ
<rdc>-inlets.extremecloudiq.com Dynamic IP range TCP 8090 Ongoing connection to ExtremeCloud IQ
