Use the Port Types menu to manage Switch Engine (EXOS) and Fabric Engine (VOSS) port types within the network policy.
Go to Configure > Network Policies, select your device, select Switching/Routing > Switch Settings > Port Types to view, create, edit, clone, and delete switch port types. For more information about port type configuration, see Configure Ports in Bulk.
To add a port type, select
To edit a port type, select the desired port type, and select
To clone a port type, select the desired port type, and select
You can filter the port types to view Switch Engine, EXOS or Fabric Engine, VOSS, or both.
You cannot delete a port type if it is currently assigned to a switch associated to any network policy.
