Supplemental CLI
View, add, modify, and delete Supplemental CLI objects on this page.
Navigate using the tab icons. Hover over an icon to see the name of the tab.
Configure > Common Objects > Basic > Supplemental CLI Objects
You can view and manage Supplemental CLI objects in this window, and in several other locations, including Supplemental CLI in Additional Settings, and Device Configuration, Modify (Multiple): Device Configuration under the Manage tab.
Before this tool is visible in ExtremeCloud IQ, you must first enable the feature in VHM Management in
admin_name > Global Settings > Administration > VHM Management.The Supplemental CLI Objects table displays the following information:
Select
and complete the fields in the dialog box. For Help about how to configure settings for a new Supplemental CLI Object, see Add Supplemental CLI.
To modify an object, select the check box and select
. Modify the Supplemental CLI commands in the CLI Commands field. When you are finished, select Save.
Select the objects you want to delete and then select
and confirm the deletion.
Copyright © 2020 Extreme Networks. All rights reserved. Published March 2020.
