MPLS.DPM.I3_Error
Description
This event indicates that a MPLS interface request has failed.
Remedy
The exact remedy is dependant on the particular situation; but the problem may be resolved by reducing the amount of resouces used by the system.
Severity
Error
Message Text
Vlan I3 error: current event = %if_event_str% interface instance = %if_instance%. desc. = %cause_str%. Return code = %retcode%
Message Parameters
Name Type
if_event_str String
if_instance uInt32
retcode sInt
cause_str String
