This message indicates MM was not able to send data over the TCP conduit to I/O.
Check the health of the I/O and whether it can be pinged from the MM. If it cannot be reached or messaged to, I/O is backed up, and an I/O reset may be needed.
Error
Error while sending data over the conduit to the I/O blades. Context %context%.
| Name | Type |
| context | String |
