Used when ospf tries to add a tent entry to SPF TENT, find a same tent with same cost as the new pent. Merge the pent to the found tent. %id%: the IP address of the pent. %data%: the IP mask of the pent. %cost%: the cost of the pent.
None. This is for debugging.
Debug-Verbose
Found tent %id%/%data% with equal cost %cost%. Merging.
| Name | Type |
| id | IPN |
| data | IPN |
| cost | uInt |
