Event occurs when an update to VLAN in ring fails. The VLAN port interface states based on ring states are not set.
Collect information from 'show memory' command. Validate the switch for enough memory. The problem may be caused due to an error sending IPML messages; reboot switch in that case.
Error
Error while setting VLAN-port state VLAN %vlan% port %port%:%slot%
| Name | Type |
| vlan | String |
| port | uInt32 |
| slot | uInt32 |
