Failed to allocate a replicated control block. The replication operation will be failed and the MIB command that attempted to create it will be returned with a failure code. This may cause some configuration information to have to be resent.
Investigate the source of the failure. It is probably due to a resource shortage on the backup protocol manager.
Warning
%p3% failed to allocate control block type %p1% identifier %p2%.
| Name | Type |
| p1 | xInt32 |
| p2 | xInt32 |
| p3 | String |
