This message logs the result code from the framework as a result to an client authentication request. Zero means frame work authenticated client.
This is a debug message, and should only be enabled on request of Extreme Networks Technical Support Center.
Debug-Summary
Client; %port%, %mac%, FrameWork result code %result%
| Name | Type |
| port | SlotPort |
| mac | MAC |
| result | String |
