Received a response (DMR) for the DMM that has been transmitted. This log will give all the four timestamps that are carried by the DMR, which are used to calculate the delay. The frame delay info is also displayed.
This message is for debug purposes only, and should only be enabled on request of Extreme Networks Technical Support.
Debug-Verbose
Cfm Segment %segName% received DMR with TxF: %txF% RxF: %rxF% TxB: %txB% RxB: %rxB% Delay: %delay%
| Name | Type |
| segName | String |
| txF | String |
| rxF | String |
| txB | String |
| rxB | String |
| delay | uInt16 |
