EtherOAM.InitTimerFail
Description
Ethernet OAM application failed to initialize timers.This should not occur unless otherwise there is a systemwide problem and all application attempt to interface with timer module fails.
Remedy
When this happens,any timer based events/functionalities may not work as expected.See if restarting the process solves this problem. Under normal circumstances this should not happen, however if it does, please escalate to engineering.
Severity
Error
Message Text
Failed to initialize Ethernet OAM timers
Applicable Platforms
