Ignored an incoming TCP tracking notification from Nettools regarding a change of state.Node state disabled or node does not exist
Check if the node exists. If it exists and this message is logged, check if the node is in disabled state.
Info
TCP track notification ignored. MemberPort:%port% TrackId:%trackId% %action% %state%
| Name | Type |
| port | SlotPort |
| trackId | uInt32 |
| action | String |
| state | String |
