When ports comes up or go down the Trunk table has to be programmed with the current set of operational members. This error indicates that there is an erorr in writing the active port information to the I/O Slot.
Disable and re-enable sharing for the given slot,port.
Warning
Failed to configure the active trunk members to the I/O slots for the trunk %slot%:%port%
| Name | Type |
| slot | Slot |
| port | Port |
