The MPF stub has tried to open more than one socket with the ATG_SCK_XSO_MRT_MPF option or multiple instances of the MPF stub have set the option. The requested multicast socket will not be available.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Request to open socket rejected - report error Diagnostic information for support: Multiple processes have attempted to set the ATG_SCK_XSO_MRT_MPF option Requesting process ID = %p1% Existing process ID = %p2%
| Name | Type |
| p1 | uInt32 |
| p2 | uInt32 |
