RTMgr stub failed to add a join to an instance of BGP. RTMgr stub cannot communicate with this instance of BGP, but continues to communicate with any other instances of BGP with which it has already established a join.
Investigate the cause of the failure and possibly restart the BGP instance.
Warning
RTMgr stub failed to create a join to a BGP instance (VR = %p1%).
Name | Type |
p1 | uInt32 |
