ExtLibA.SockLib.SetTCPMD5OptFail
Description
Failed to set TCP MD5 password option because of sockets error.
Remedy
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Severity
Warning
Message Text
Failed to set TCP MD5 password option. Sockets error code = %p1% Socket ID = %p2% Socket type = %p3% Socket family = %p4% Socket protocol = %p5% Application handle = %p6% Stub socket handle = %p7%
Message Parameters
Name Type
p1 sInt
p2 sInt
p3 xInt32
p4 xInt32
p5 xInt32
p6 uInt32
p7 uInt32
