The Power Fan Controller located on the MSM has reported a warning that the chassis temperature is reaching the limits of the operating range. If the temperature does not return to normal, the PFC could shut down the chassis.
Replace the fans if they have failed or improve air circulation around the system.
Warning
%sensor% Chassis air intake temperature %temp%. System shutdown may occur if corrective action is not taken. System shutdown will happen at 50C.
| Name | Type |
| temp | String |
| sensor | String |
