Informational. Configuration database will be locked/unlocked when there is application failure. Depends on the recovery level of the application, the application might get restarted or the MSM might failed over.
If the database stay locked (user cannot issue any CLI commands), a reboot of the MSM might be needed.
Warning
Configuration database %status%
| Name | Type |
| status | String |
