During IO slot boot up, PVLAN library sync from MM to IO has failed. PVLAN or VLAN Translation will not behave properly.
Library sync is done at IO boot up. "disable slot <slot>" will turn off the slot. "enable slot <slot>" will power it up again.
Error
During bootup of IO %slot%, PVLAN library sync with IO has failed
| Name | Type |
| slot | Slot |
