BGP.RtMgr.RegFail
Description
BGP RtMgr agent failed while registered with RtMgr for specified instance and Afi/Safi.
Remedy
This is an unexpected internal condition. Try disabling and enabling BGP first. Then attempt to restart BGP. If failure persists, this may be a problem needing technical assistance. Contact technical support with the following information: "show tech" and "upload debug". System Restart may be required for continued operation.
Severity
Warning
Message Text
[VR %vrid%] Register: %reg%: ret=%ret%
Message Parameters
Name Type
vrid VRID
reg String
ret sInt
