HAL.Port.OpticAutoNegDefault
Description
Auto-Negotiation enabled by default for fiber ports 25G and above. Check the peer port auto-negotiation setting as it should be the same.
Remedy
No action required - Notification message only.
Severity
Notice
Message Text
Auto-Negotiation enabled by default for the transceiver module in port %slotPort%. Please verify that the peer has the same setting.
Message Parameters
Name Type
slotPort SlotPort
Applicable Platforms
