A component on the management module failed to get the flags for a file descriptor during I/O blade initialization. Look up the errno definition for a more specific cause.
Restart the IO module by disabling and enabling the slot. Or Report the problem to your switch support contact.
Error
An attempt to get the flags for file descriptor %sockfd% failed retuning errno %errnoNum%(%errnoStr%) for slot %slotNo% and conduit Type %conduitType%.
| Name | Type |
| slotNo | uInt |
| conduitType | String |
| sockfd | sInt |
| errnoNum | sInt |
| errnoStr | String |
