Hardware programming to set the egress of an access virtual port failed. Forwarding is impacted. This should not happen and is an internal error.
This is a rare internal condition needing technical assistance. Contact technical support with the following information: configuration, and the "show log" output.
Error
Failed to set access egress for virtual port %vp%.
Name | Type |
vp | uInt32 |
