Multiple LLDP peers have been detected on the given port while running DCBX. The number of peers detected is given in parenthesis after the work "Multiple". DCBX is only supported on point to point links, so this is an unsupported configuration.
Disable DCBX on the given port, or reconfigure the network so that there is only one LLDP peer on the given port.
Warning
Multiple(%numPeers%) LLDP peers detected by DCBX (%dcbxVersion%) on port %slotPort%.
| Name | Type |
| numPeers | uInt16 |
| dcbxVersion | String |
| slotPort | SlotPort |
