Incomplete data message read from an SCTP socket.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Warning
Incomplete data message read from an SCTP socket. Socket ID = %p1% Stream number = %p2% Received flags = %p3%
| Name | Type |
| p1 | sInt |
| p2 | sInt |
| p3 | xInt16 |
