An attempt to send a conduit event message to all slots failed. The underlying system socket has failed and is closed as part of the recovery.
Switch will restart the IO slot that caused this error. If the slot is not restarted, disable the slot and enable it again.
Warning
A conduit event transmission failed for slot %slotNum%, conduit type %conduitType%, file descriptor %fd%, event flags %evntFlags% and event seq. # %seqNo%.
| Name | Type |
| slotNum | uInt |
| conduitType | String |
| fd | uInt |
| evntFlags | uInt8 |
| seqNo | uInt16 |
