This event traces a MPLS RSVP LSP bandwidth set request. The system is functioning as expected.
N/A.
Debug-Data
Bandwidth set req.: Ingress size = %IngBwReq% Egress size = %EgrBwReq% hold pri. = %hold_pri%. interface = %if_name%. seg type = %set_type% Hold In-use bw = %InUsePri% Total In-use bw = %InUseTot%
| Name | Type |
| if_name | String |
| set_type | String |
| IngBwReq | uInt32 |
| EgrBwReq | uInt32 |
| InUsePri | uInt32 |
| InUseTot | uInt32 |
| hold_pri | uInt32 |
