HAL.Port.GBICFEFIBatchEnbl
Description
FEFI mode enabled for ports set in the 64 bit port Map. If there are any errors, error will be non zero and bit set will indicate that the corresponding port did not have FEFI enabled.
Remedy
There is no remedy because there is no problem to be resolved.
Severity
Debug-Data
Message Text
FEFI mode enabled in batch for port map %fefiPortMap% error %errorCode%
Message Parameters
Name Type
fefiPortMap xInt64
errorCode xInt64
Applicable Platforms
