NetLogin needs to add all port enabled for NetLogin to the NetLogin VLAN. For some reason this failed for the mentioned VLAN on the specific port.
This should only happen if the NetLogin VLAN has not been configured correctly. i.e. IP-Forwarding disabled, a valid TAG is assigned, and no ports are added. The result for now is always zero, this migth change in the future.
Error
Failed to add the NetLogin VLAN, %vlan%, to port %port%, reason %reason%
| Name | Type |
| vlan | VLAN |
| port | SlotPort |
| reason | sInt |
