Configuration save failed due to timeout while waiting for backend modules response. Backend modules could be still be servicing previous command requests.
This is an internal condition related to software. Check abnormal processor utilization of any process using 'show process'. Retry the command after some time. If the issue persists, contact technical support and provide outputs of 'show switch', 'show log', 'debug cfgmgr show clients'.
Error
Save configuration failed due to %n% unresponsive application(%apps%).
| Name | Type |
| n | uInt |
| apps | String |
