ExtLibA.SockLib.JoinMcastGrpFail
Description
Multicast group join error.
Remedy
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Severity
Error
Message Text
Failed to join Multicast group. Sockets error code = %p1% Multicast group address = %p2% Socket ID = %p3% Socket type = %p4% Socket family = %p5% Socket protocol = %p6% Application handle = %p7% Stub socket handle = %p8%
Message Parameters
Name Type
p1 sInt
p2 VarFmtByteArray
p3 sInt
p4 xInt32
p5 xInt32
p6 xInt32
p7 uInt32
p8 uInt32
