A socket close attempt failed. There may be no immediate effect, but it is possible that some resources have not been freed, which may result in a failure to open a socket at some later time.
Examine other diagnostics (including those of the IP stack) for a reason for the failure. If this does not resolve the problem, contact support with details of the problem.
Warning
%p1% Failed to close socket. Error code = %p2%
| Name | Type |
| p1 | String |
| p2 | sInt32 |
