A management module component, initializing IP connections to I/O blades or processing a request to reconfigure the number of executing threads, has detected an invalid socket file descriptor. The conduit connection database may be corrupted.
This is possibly the result of internal data corruption or a software programming error. Report the problem to your switch support contact.
Error
An attempt to add an invalid file descriptor %connFd% to a conduit database was detected for slot %slotNo% and conduit type %conduitType%.
| Name | Type |
| slotNo | uInt |
| conduitType | String |
| connFd | sInt |
