HAL.VLAN.CkptNotRdy
Description
Due to the system configuration, check-pointing is not on. When check-pointing is not enabled, MM-failover is not working properly in the dual MM system.
Remedy
This message is a warning in case check-pointing is off by accident. Refer User's manual to enable check-pointing.
Severity
Warning
Message Text
Check-pointing is not ready.
Applicable Platforms
